Problem with my MK4
Boyko Kostov
(@boyko-kostov)
Utenti
Problem with my MK4
Hello, everyone!
Can someone please explain to me why my pritner is doing this nonsense and shifting the print by 4-5 sentiments in some direction?
Could it be the speed because I'm running it at about ~500 print speed?
Or could it be some setting? Though I think I've looked at everything, ugh?
Interestingly, this problem only occurs when I print something with a larger height and it starts to shift after about 6-7 inches?
I use Prusa MK4 and Prusa slicer
PLA but i'm doubly about the brand - its between Fiberlogy or Polymaker
Nozzle 0.4, ~220temp C , Bed temp - ~60temp C
Thank you all!!
Postato : 10/05/2024 10:41 am
Lynn
 Lynn
(@lynn)
RE: Problem with my MK4
Assuming you mean 500mm/sec.  That seems pretty fast. The stock MK4 IS profile for PLA runs the printer at 170mm/sec.
Have your tried slowing it down
Postato : 10/05/2024 2:54 pm
1 persone hanno apprezzato
Boyko Kostov
(@boyko-kostov)
Utenti
Tonight I ran it at normal print speed and it came up correctly, but yeah, it was still all night.
Is it also possible that the infill percentage I filled it with is the problem too, I had it running at 10%?
On the Prusa mini I'm printing parts at 200 print speed and everything is perfect, my MK4 is brand new and when I saw it had the option of 900 and decided to test in the middle 🙂
P.s. I'm newbie and think obviously I'm going to be throwing a lot of scrap until I figure out the capabilities of the printer 😀
Thanks so much for the reply! Be healthy
Postato : 11/05/2024 10:35 am
