Printing ABS
AvariCe
(@avarice)
Printing ABS
Hello all,
I recently ordered the mk4 kit with the enclosure. My question is, will I be able to print ABS safely with these two, or will I need the advanced filtration addon (or whatever it's called)?
Thanks for reading.
Posted : 09/12/2023 10:36 pm
Zappes
(@zappes)
RE: Printing ABS
You can print without filtration, but printing ABS does produce some toxic fumes you don't want to inhale. That's probably OK if your printer is in a well-ventilated garage or so, but if you have it in the same room you are in, you should have some kind of filtration system in place.
My models on Printables
Posted : 10/12/2023 10:32 am
Spinnetti
(@spinnetti)
RE: Printing ABS
I've been doing a fair bit of ABS with my MK4 (never got good results with the MK3) in my home office, and I don't really notice fumes or anything nasty (Hatchbox filament). I did make a foam posterboard (paper/foam sandwich)  enclosure that cost just a couple bux though, and it keeps the heat even, any fumes contained and dust off the working bits.
Posted : 17/12/2023 1:01 am
