Print pause problem MK4
I'm having this problem with the printing pause, after inserting the nut on the first layer from the restart the filament is not under pressure, creating a lack of filament, has this happened to anyone?
RE: Print pause problem MK4
So you advice your printer to take a break so you have enough time to insert a nut mid-print and then the print suffers from underextrusion?. Is filament oozing out the nozzle during the break? Maybe you need to add a wipe- & reprime routine.
RE: Problema di pausa di stampa MK4
Thanks to Prusa support we discovered that the problem only occurs with the IS profile, in normal mode everything works.
I have had some weird results with IS. I am not sure why this would happen.
Has anyone tried doing a press break with the MK4?
After having done other tests, the problem occurs with all the firmware, so to put a magnet I have to do it with the color change.
