Print pause problem MK4
MoNkEy
(@monkey)
I'm having this problem with the printing pause, after inserting the nut on the first layer from the restart the filament is not under pressure, creating a lack of filament, has this happened to anyone?
Maybe you have a solution.
Respondido : 25/12/2023 10:43 pm
1 les gusta
the-powl
(@the-powl)
RE: Print pause problem MK4
So you advice your printer to take a break so you have enough time to insert a nut mid-print and then the print suffers from underextrusion?. Is filament oozing out the nozzle during the break? Maybe you need to add a wipe- & reprime routine.
Respondido : 26/12/2023 12:47 pm
MoNkEy
(@monkey)
RE: Problema di pausa di stampa MK4
Thanks to Prusa support we discovered that the problem only occurs with the IS profile, in normal mode everything works.
Respondido : 26/12/2023 1:29 pm
2 les gusta
Miembro
I have had some weird results with IS.  I am not sure why this would happen.
Posted by: @m3d-2
Respondido : 14/01/2024 1:51 pm
1 les gusta
MoNkEy
(@monkey)
Has anyone tried doing a press break with the MK4?
After having done other tests, the problem occurs with all the firmware, so to put a magnet I have to do it with the color change.
Respondido : 17/01/2024 2:33 pm
