PETG flat vs satin/semi-gloss top layer finish
TMASlide
(@tmaslide)
Happy Holidays all!
Over the last month or two I've re-sliced various objects for printing using the generic preset among others. Since overriding previous files and their settings, the prints end up with a flat top finish using PETG vs the satin/semi-gloss top layer I've always had previously. I have not found a way to control the finish. This is happening with filaments I've used for a while. Any ideas would be appreciated. Recent software updates? Firmware related? Obscure print setting?
Prior to these recent results, everything I've printed (1,000s of objects) I never saw a flat finish. Now that I'm seeing some, some objects might benefit from this finish while others a satin/semi-gloss finish would be preferred. Knowing how to manage the top layer finish should be an obvious setting, correct?
Best Answer by Brian:
It's the increased print speed.  The faster it prints the duller the finish tends to get because the plastic is not spending as much time getting heated in the nozzle.  I see this as a sign of nearing underextrusion, which can be bad.
The fix in most cases is pretty simple, raise your nozzle temperature.  I find that 240-250 is good for the IS profiles depending on your filament supplier.  I've found that Polymaker needs 250, while Hatchbox is good at 240.
If that doesn't solve it I recommend lowering your volumetric flow rate in the filament profile.  Essentially this will limit maximum print speeds based on the required flow.
Napsal : 18/12/2024 11:16 pm
Brian
(@brian-12)
RE: PETG flat vs satin/semi-gloss top layer finish
Napsal : 19/12/2024 1:08 am
1 lidem se líbí
