Object Image on screen
iftibashir
(@iftibashir)
Older firmware used to show an image of the actual object/model prior to printing (and while printing).
I see this has gone with recent firmware updates, although is there a way to see the model on screen prior to printing?
Best Answer by FoxRun3D:
Oh yes. That's not the stock setting for a Mk4 in the new firmware. They now use QOI format instead of PNG. I don't know why your profiles apparently didn't update. Maybe reinstall PS.
Veröffentlicht : 14/02/2024 10:33 am
pa1ntman
(@pa1ntman)
RE: Object Image on screen
You might wanna check your firmware….
https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-general-discussion-announcements-and-releases/5-1-0-no-option-to-display-image-of-print-objct/#post-688230
Veröffentlicht : 14/02/2024 11:23 am
iftibashir
(@iftibashir)
Hmmmm.....thought I was up to date. Sure I updated to 5.1.2 - will double check later!
Thanks!!
Veröffentlicht : 14/02/2024 11:29 am
You've got to slice your projects again as they changed the image format.
Veröffentlicht : 14/02/2024 12:24 pm
iftibashir
(@iftibashir)
Seems everything is up to date as I suspected......
PrusaSlicer 2.7.1
MK4 Firmware 5.1.2
Newly sliced object and still do not see any image on the MK4.
Is there a settings I'm missing somewhere?
Veröffentlicht : 14/02/2024 1:13 pm
Do you by any chance use a custom printer profile? Do you have the QOI formats in the thumbnail settings?
Veröffentlicht : 14/02/2024 1:17 pm
iftibashir
(@iftibashir)
I haven't touched anything - I generally just use defaults. Only thing I ever change is infill or supports/brim!
Screenshot attached - should I change this to QOI?
Veröffentlicht : 14/02/2024 1:22 pm
Veröffentlicht : 14/02/2024 1:25 pm
iftibashir
(@iftibashir)
Works when I change it to QOI!!!
I will reinstall the software - thanks!
Veröffentlicht : 14/02/2024 1:30 pm
iftibashir
(@iftibashir)
Completely removed the software, then reinstalled - all OK now 😉
Thanks!
Veröffentlicht : 14/02/2024 3:41 pm
