My part is not clean
stanton
(@stanton)
Mitglied
Im printing a small part 17mm long 5mm wide 15mm tall.   Im using PET  with a .3 tip.   no matter with quility i make it in it still comes out rough looking.     can i get help on this.    steve
Veröffentlicht : 12/02/2024 4:33 am
Lynn
 Lynn
(@lynn)
RE: My part is not clean
please post a pic
Veröffentlicht : 12/02/2024 1:14 pm
stanton
(@stanton)
Mitglied
I hope you can see my issue with the photos I sent you
Diese r Beitrag wurde geändert Vor 2 years von stanton
Veröffentlicht : 13/02/2024 2:55 am
stanton
(@stanton)
Mitglied
Do you have any idea why it would be printing  this way, it's also very stringy.
Veröffentlicht : 14/02/2024 4:35 am
pa1ntman
(@pa1ntman)
You indicated PET, assume you mean PETG? Looks like your filament is ‘wet", it has absorbed too much moisture.  there are a number of ways it can be dried out, from  commercial dry boxes which can range from 30-100 dollars, dyi dry box with silica desicant, old food dehydrator, I have even seen folks stick in an oven at very low temperature (100degrees)for an hour or so.
Veröffentlicht : 14/02/2024 10:59 am
stanton
(@stanton)
Mitglied
Thanks do you think that's the main problem? I have a dryer just never thought to use it.
What size nozzle should I use for a small part like this, can I have your suggestion.
Veröffentlicht : 15/02/2024 3:01 am
pa1ntman
(@pa1ntman)
PETG can make a mess  when it’s wet. Your nozzle size is probably fine, although I have never used anything smaller than a #4, and have printed lots of objects even smaller than yours ( tiny 3 mm button plugs for the prusa enclosure) dry that filament out and give it another try.
Veröffentlicht : 15/02/2024 11:05 am
Make drying your new religion.  If you can, dry after every print and store ziplocked with dessicant.  If it's been more than a couple of months since last time you used it  - dry again before printing.
Unless the tolerances are particularly tricky 0.4 should be fine.
Veröffentlicht : 15/02/2024 12:14 pm
