MK4S - XObsidian compatible?
Good morning,
I am curios if the new MK4S will be also compartible with XObsidian nozzle or if it will be a new nozzle for the Upgrade Kit? Normally the Nextruder adapter is compatible with the MK4S so the XObsidian nozzle should be also compatible. But the new fan has more power so the standard profiles will be not compatible with new fan and the newq profiles are optimized for newer nozzle and fan but will maybe not work correct with the XObsidian nozzle. Has someone experience with this combination?
RE: MK4S - XObsidian compatible?
There are new obxidian high flow nozzles.
https://www.prusa3d.com/product/e3d-prusa-nozzle-high-flow-obxidian-0-4-mm/
When i spoke to prusa support they told me to keep using the obxidian as the mmu3 doesnt work well with the new high flow nozzles. They will probably get it working better at a later time though, not quite sure. But yeah the obxidian will work with the mk4s
