MK4 Texture Sheet not sticking
Gator
(@gator)
MK4 Smooth sheet works fine, but when I tried to used the MK4 textured sheet nothing sticks after the 1st layer.  Does the slicer need to know what type of plate I'm using.  Plate is new and I have cleaned it per Prusa instructions.  Filament is ASA.  Using new prusa slicer.
Respondido : 17/04/2023 4:53 pm
Walter Layher
(@walter-layher)
RE: MK4 Texture Sheet not sticking
I would use some kind of glue in this case, either gluestick or 3dlac. I haven't printed ASA on my MK4 yet, but on the MK3S+ this was the same behaviour you describe. A brim also helps with adhesion. And the slicer does not need to know the type of the sheet, that is the job of the printer.
Respondido : 17/04/2023 5:00 pm
Cynan
(@cynan)
You don’t need to tell the slicer what sheet you’re using no… but ASA doesn’t stick to well to the textured sheet and it’s recommended to use a glue stick with the textured sheet.
https://help.prusa3d.com/materials
Respondido : 17/04/2023 5:01 pm
Gator
(@gator)
My MK3 textured sheet work great, no glue needed on ABS, ASA, PLA.  I will use glue, just thought maybe the Z needed to be lowered.  Not to sure that can happen on the MK4.  Thanks for the info.
Respondido : 17/04/2023 5:07 pm
