MK4 Heated Bed LCD Temperature Mesurements Seem to be Incorrect.
ZZTOP
(@zztop)
Membre
I had some warping of corners on parts which were "close" to the outer edges of the heated bed, but when I printed the parts directly in the center of the heated bed, warping did not happen.   I made sure the heated bed and the textured sheet was perfectly clean. I was using PETG, starting the first layer at 85C then dropping back to  65C for the remaining layers.  So I sampled various heatbed temperature settings using a small point thermocouple probe on my Fluke 17B+ multimeter to make the measurements:
I chose to sample around the middle of the bed and the front right of the bed ( yellow X's):
I made measurements from 65C to 100C, dialed in on the MK4 LCD panel. My results:
MK4          Center         Right Front
LCD            Probe             Probe
Setting     Reading        Reading
65C            54C               53C
70C            56C               58C
75C            60C               63C
80C            64C               68C
85C            68C               72C
90C            72C               77C
95C            76C               82C
100C          80C               86C
It appears the LCD heatbed temperature does not match my probed temperature by quite a bit.
I confirmed the accuracy of my probes by screwing the V6 nozzle temperature probe (blue box) into the hot end instead of a nozzle, while simultaneously pressing the Fluke probe onto the hot end. The MK4 LCD and my probes all measured almost the exact same temperatures across a range of MK4 Nozzle heat temp settings.
The heat bed and heat bed thermistor (installed at factory) are brand new from Prusa and had never been used.
I wish there was a way in the LCD settings panel to add "offsets" to apply to the heatbed temperature to bring it more in-line with the correct temperature. Without this a guess I will have to skew my temp settings in the slicer, specific to my MK4?
Publié : 26/10/2024 2:57 am
ZZTOP
(@zztop)
Membre
Re: MK4 Heated Bed LCD Temperature Mesurements Seem to be Incorrect.
I printed test parts that warped when heatbed was set to 85c ; used adjusted temp setting to 100c, based on my measurements, effectively giving me an actual temp of  80c - 86c range, and now no warping! Nothing was changed in the Prusa Slicer settings except for the heatbed temperature.
Publié : 27/10/2024 12:55 am
