MK4 extruder / heatbrake fan speed during printing
[Solved] MK4 extruder / heatbrake fan speed during printing
AK
 AK
(@ak-4)
Hi! I've question related to MK4. Suppose that room temperature is around 21-22C and I'm printing with hotend temperature set to 225C.
Question: What is yours extruder (heatbreak) fan speed??
Mine ramps up to 8000 RPM most of the time (100%) and it's very loud. Heatsink temperature is around 37-38C. Comparing to MK3s Noctua's a it is night and day difference. I know that this Delta fan has higher airflow rating but I'm wondering why it is running so high...
Napsal : 28/11/2023 10:50 am
AK
 AK
(@ak-4)
RE: MK4 extruder / heatbrake fan speed during printing
Here is video showing this issue: MK4-heatbreak-fan-100.mp4
Napsal : 28/11/2023 12:10 pm
Patrick.b
(@patrick-b)
Posted by: @ak-4
could you resent video pliz ! link dead or not working ? thx
Napsal : 30/07/2024 5:56 pm
AK
 AK
(@ak-4)
Hi. Video is public and the link should work OK.
Napsal : 31/07/2024 6:04 am
sacrelege
(@sacrelege)
I have the same noise "issue". So the firmware or the slicer sets the heatbreak target temp to 36°C and the it will try to reach that, which is barely possible even with a environment temperature of 21°C imho. so the fan ramps up to max speed and causes endless noise.
if you use octoprint you can submit the following gcode in terminal (on your own risk ofc.!)
M142 S40; set heatbreak target temp to 40°C (default is 35/36°C)
and you will pretty much immediately see how the fan speed reduces until 40°C is reached or the setting gets overwritten (maybe it will be reset during layer change or something, I'm not sure, but it doesn't seem to stick).
I think the passive cooler on the mk4 is too small or a bad design and maybe the target temp is also set to restrictive, but I don't know if there are side effect if the settings is constantly set to a higher value.
This post was modified před 2 years by sacrelege
Napsal : 31/07/2024 2:46 pm
1 lidem se líbí
Patrick.b
(@patrick-b)
Posted by: @ak-4
here what i've got !!
Napsal : 31/07/2024 3:58 pm
Patrick.b
(@patrick-b)
well i tried on edge and works fine .. !! got prob with mozilla !! thx
Napsal : 31/07/2024 4:00 pm
Patrick.b
(@patrick-b)
Posted by: @ak-4
ok i just watch it ..but i would wish see the same with 1 fan shroud to see the difference !! and analyse !!
Napsal : 31/07/2024 4:04 pm
derEnCh
(@derench)
My MK4 Kit (no Upgrade) is also running with 100% hotend fan shortly after the hotend is heating.
Exactly the same behaviour as shown in the video from @ak-4.
Compared to my MK3 the new MK4 is a lot louder. Anoying as I expected noise reduction as advertised.
Has anyone already talked to the Prusa Support? Any particular reason why the Heatbreak target temperature is set so low? I would expect a lot more users complaining about it.
Napsal : 18/08/2024 11:34 am
Comp
 Comp
(@comp)
Any update? I tried to talk to the support but nothing came out of it. It's so loud
Napsal : 15/02/2025 10:53 am
derEnCh
(@derench)
Support sent me a new heatsink thermistor, however I feel its not the causing issue.
I will wait for the Core upgrade, the case should isolate the nois a bit.
Napsal : 17/02/2025 7:02 am
Comp
 Comp
(@comp)
I see. They sent me a new fan. It was good to eliminate it, but it wasn't the issue.
Napsal : 10/03/2025 12:23 am
