MK4 and Flex (TPU)
Stránka 2 / 2
Walter Layher
(@walter-layher)
RE: MK4 and Flex (TPU)
You mean the planetary gears? But for this operation you don't have to disassemble the extruder. Just the screw holding the lever. The cover plate stays on.
Napsal : 06/01/2024 10:34 am
1 lidem se líbí
miroslav.h4
(@miroslav-h4)
I just can't get to the tension lever mounting bolt, my transmission cover only has three bolt holes. There is no hole in the place of the tension lever screw and I have to remove the cover. And when handling an open gearbox, anything can move. Hence the recommendation on the calibration of the gearbox.
Napsal : 06/01/2024 3:21 pm
1 lidem se líbí
Walter Layher
(@walter-layher)
Member of the four screw crew here. I guess early adopting has not just its drawbacks. 🙂
Napsal : 06/01/2024 3:51 pm
1 lidem se líbí
Stránka 2 / 2
