M92 command
ExactShape Solutions
(@exactshape-solutions)
M92 command
Hi !
Did anyone try, with success, to correct X/Y/Z dimensional accuracy using M92 command ?
I use it, with the start g code, to set up my mk3s+ with a very great success (imagine Borat, here).
I can achieve 0.03mm accuracy, which is amazing.
But I can't figure out how to manage it with my mk4 : at first, it messed up the homing. So I moved it further in the start g code. And it does not affect the dimension as I want, as it does on my mk3s+.
If I try to modify it with a larger scale, as 1/2 on X or Y axis, it works : my 20mm part is 10mm on X or Y. But it does not work for minor adjustments.
Did I miss something ? As Y is nearly perfect, I start to think that this printer is made for accuracy, just OOB. And the X axis belt is just not correctly tighten.
But I would prefer the M92 way, which is more convenient and provides (on my MK3S+ only....) excellent results.
Thanks !
Posted : 30/01/2024 9:57 am
RE: M92 command
No one ? I'm a bit surprised...
Posted : 07/02/2024 3:41 pm
Area51
(@area51)
RE: M92 command
I haven't used M92 on MK4 recently.
If the command works well on MK3S+ but causes issues on MK4 with smaller adjustments, it might be a firmware problem. Consider raising the issue on GitHub under Buddy firmware issues for assistance.
Your observation on the X axis belt tension is valid. Hope you find a solution!
Posted : 10/02/2024 3:54 pm
RE: M92 command
Thanks for the reply !
In fact, I finally went through the belt tension process, and it was worth it ! I let the things go as it is for now !
Posted : 10/02/2024 4:59 pm
