[Gelöst] Issues when printing with TPU 60A
Marcus
(@marcus-5)
Have a friend how has printed with "Filaflex 60A Pro Svart" with great results.
But when I tried on my MK4 it does not work.
The settings is as recommended for that material.
Also tried to:
Increase the temp
Reduced the speed
Increase flow
Anyone tried to print soft TPU with good resault?
Regards
Marcus
Best Answer by Marcus:
Fixed. It was me that had changed a setting in a way that was not that clever 🙂
Now works good.
Only issue is that the filament is not possible to load due to the softness of it.
To load it I removed the smal steel spring that pushes the steel ball in the filament sensor, so the filament could pass.
Next I snapped opened the filament "push bracket(?)" so I could see that the filament entered the correct way. Loosened the pressure a little as well.
Then good to go.
Veröffentlicht : 15/02/2024 12:57 pm
Brian
(@brian-12)
What are the recommended print speeds from the manufacturer of your filament.  That's where I'd start.
I'm my experience TPU needs to be printed slow.  I don't use input shaper on tpu.
You also need to make sure the filament is dry.  TPU absorbs moisture from the air and it will contribute to poor quality prints. I recommend you dry the filament for the best results.
Veröffentlicht : 15/02/2024 3:11 pm
Marcus
(@marcus-5)
RE: Issues when printing with TPU 60A
Now works good.
Then good to go.
Veröffentlicht : 16/02/2024 6:29 am
Volker
(@volker)
Which setting was wrong?
Veröffentlicht : 16/02/2024 6:46 am
