How to edit my model description on Printables.com?
KLR-Tom
(@klr-tom)
Utenti
I have searched but not found the answer.
All I need to do is to edit the name of the model I uploaded to better describe it. However, no matter how I try to do that, the software insists that I upload the model files again. Surely there has to be a way around this?
Postato : 29/03/2024 8:16 pm
Walter Layher
(@walter-layher)
RE: How to edit my model description on Printables.com?
On the right hand side next to the title of your model there are three dots. When you click there, a menu appears with the option "Edit".
Postato : 29/03/2024 10:04 pm
KLR-Tom
(@klr-tom)
Utenti
Thanks Walter but I tried that.  It lets me make edits to the title or to the description of the model, but then when I select "publish", it says I have to upload a model file.  Since the model file has not changed I should not have to find it and upload it again.
Postato : 29/03/2024 10:22 pm
Walter Layher
(@walter-layher)
I tried the same on one of my models, I changed the title, clicked on "publish now", the changed title appeared, and then I changed it back which also worked. I did not have to upload anything. I did change something in every one of the text fields and that worked also without requiring additional uploads. The model I used to test this has two .3mf files, as well as one .f3d and one .step file.
Perhaps this is just another quirk of the forum software. Sometimes when I add a make I can add stars, sometimes I cannot, don't know why.
Postato : 30/03/2024 12:04 am
KLR-Tom
(@klr-tom)
Utenti
Thank you so much for your detailed responses Walter.
I tried many things and finally had success.  Here is what worked for me:
There are a series of check circles and I had to check the one that said "Model Origin - I made it" and the text below that said "I am uploading a new model". Once I selected that check circle, it allowed me to publish my changes but did not ask for me to actually upload a new model. Weird, but it works.
Postato : 30/03/2024 11:10 am
