Filament stuck in extruder somewhere
Garrett Cannon
(@garrett-cannon)
Miembro
My MK4 is having problems. I got halfway through a 8hr print when filament just stopped coming out. I tried to purge but the gears just kept slipping along the filament and did the same thing when trying to unload. I had to open the side clip thing to relieve some pressure and then use pliers to pull it up and out. The filament morphed a bit from the gears trying to push it down and made it a bit fatter where it was broke causing it to not want to come back out when unloading. I got a couple smaller prints out of it before it happened again. Except this time whatever is stuck is further past the gears. I tried heating the nozzle and sticking the acupuncture needle up it and that didn’t do anything. If I try to load filament and purge then the gears just slip along the filament again. I have no idea what to do. I don’t want to just start taking things apart with a guide
Respondido : 21/08/2023 8:32 pm
str0gg
(@str0gg)
RE: Filament stuck in extruder somewhere
Is it shape like this one?
mini+ [bondtech dual drive, revo, reprinted with PA11-CF and ASA] lives in photo tent.
mk4 upgraded to S with mmu3 and gpio (with some parts reprinted) lives in prusa enclosure.
Voron 0 ldo kit with dragon burner and…
Respondido : 23/08/2023 10:01 am
Garrett Cannon
(@garrett-cannon)
Miembro
I assume so. I took the nozzle tube thing out and i see the filament in there. How did you get it out?
Respondido : 24/08/2023 3:16 am
str0gg
(@str0gg)
This is adapter, between it and full nozzle there is no difference in problematic copper? part. It forms this cylinder of doom due to temperature change. I have no idea why they design it like this… How to get it out? Heat gun (better because temperature control is crucial) or lighter.
Respondido : 24/08/2023 7:49 pm
