An Optimized PrusaSlicer Config for the MK4
Nate DiSalvo
(@nate-disalvo)
In talking with people here and on Reddit, I received some interest in the MK4 configuration I have made and optimized over the last few months. It has been tested for over 2500 hours on 7 different MK4 printers, both assembled and kit versions. It increases the extrusion flow to 22mm^3/s because I found that PLA at 225C is capable of that flow on the Nextruder without problems. This allows for increased print speeds, and I also made some other setting changes to help with quality.
https://github.com/D3Design/MK4-Prusaslicer-Configurations
Napsal : 17/03/2024 5:54 pm
Pepan se líbí
Pepan
(@pepan-3)
RE: An Optimized PrusaSlicer Config for the MK4
Hi, I have problem importing the file.
PrusaSlicer is 2.7.2.
I download the file and then trying to import (file - import - import config)
I get an error:
Failed loading the Config Bundle "": '=' character not found in line at line 7
Do you know why?
Napsal : 19/03/2024 6:34 pm
idiogenic
(@idiogenic)
Nate, what filament are  you using? I have tried this profile with Prusament PLA and Polymaker PLA and unfortunately get noticeably worse results.
Napsal : 27/03/2024 11:12 pm
Katakana54 se líbí
Pepan
(@pepan-3)
Tried it again today and settings imported without problem. Will give it a try!
Napsal : 01/04/2024 3:55 pm
