6.0.3 Firmware for Original Prusa MK4
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
Summary
  • Interim solution of USB disconnect issues (MK4, MK3.9, MK3.5, XL)
  • PINDA off-bed probing repaired (MK3.5)
  • Screenshot procedure fix (MINI)
The developers have thoroughly reviewed the part of the firmware responsible for unexpected USB disconnects, which lead to print interruptions that cannot be resumed. As a quick hotfix, we have added the option to continue printing after this interruption.
However, we will continue to seek a definitive solution to this problem.
Moved bed leveling probing points to avoid probing measurements out of the heatbed area. This issue was reported on GitHub as #3851.
Fixed an issue where the screenshot procedure ended with a blue screen of death (BSOD).
Summary
Release notes: https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.0.3
Opublikowany : 24/06/2024 3:22 pm
sameo416
(@sameo416)
RE: 6.0.3 Firmware for Original Prusa MK4
Just applied this update, and can no longer see printer status over WiFi. It says 'connected' on the printer display. I updated the printer config file to ensure the correct network credentials were there, the printer screen loads on my pc (with no password), but no data displays. All was ok before the firmware flash. The WiFi logo is displayed on the printer.
Opublikowany : 25/06/2024 3:57 pm
sameo416
(@sameo416)
It's only with Chrome. Tried clearing everything, still displays no data. Firefox works fine.
Opublikowany : 25/06/2024 4:13 pm
Busy With 3D Printing
(@busy-with-3d-printing)
When is the next major firmware update?
Opublikowany : 28/06/2024 12:42 am
1 ludzie polubili
