[Résolu] Y Motor threading defect?
jamesan
(@jamesan)
I just got my Mk 4 kit.  I’m at step 31 where I screw the  Y motor holder to the Y motor.  The middle screw won’t go in and the hole on the Y motor appears to be filled with a clear hard material (glue?) and I can’t tell if the hole goes down to the required depth.  This appears to be a manufacturing defect.  What next?  Can I rotate the holder to use the three good holes or is cable orientation critical? Bad hole in bottom left Bad hole in bottom left
Publié : 26/12/2023 11:40 pm
jamesan
(@jamesan)
Bottom Right is the problem hole.
Publié : 27/12/2023 12:56 am
jamesan
(@jamesan)
RE: Y Motor threading defect?
I started a chat with tech support that I noticed in assembly guide website and they took care of it.  Thanks!
Publié : 27/12/2023 7:02 am
Justin
(@justin-3)
What ended up being the issue? Just asking as it may be helpful to others encountering the same (or similar) issues.
Publié : 31/12/2023 9:38 am
jamesan
(@jamesan)
Chat didn't say specifically.  I sent them the photo.  They said "Oh, that doesn't look good" and we immediately went down the path of sending a replacement Y-motor in the mail.  My guess is during manufacturing whatever process their supplier used to tap the screw hole failed.  Prusa gave me a great support experience.
I tried posting the photo into this thread twice and it doesn't appear for me.  Not sure why that is.
Publié : 31/12/2023 6:59 pm
Hi Jamiesan,
what ever you did to insert your photo, added a load of formatting information which effectively prevented the picture from displaying.
I removed these comments on an earlier post, and your picture now displays
Regards Joan
Publié : 31/12/2023 7:39 pm
jamesan
(@jamesan)
Thanks!  And now that it posts I can see my caption was wrong. 🙂  It is the bottom right hole that did not tap correctly.
Publié : 31/12/2023 8:08 pm
Is that better?
Joan
Publié : 31/12/2023 10:08 pm
