XBuddy Board assembly issue
Gary
 Gary
(@gary-8)
I've been assembling  the MK4 kit. When I got to the step that called for mounting the xbuddy circuit board into it's case I found that the holes in the board and the threaded inserts in the case didn't line up. So I couldn't attach the board to the caee.
I wrote to Prusa nearly a week ago asking for suggestions but they have not replied. Do you have any suggestions?
Gary
Napsal : 09/10/2023 1:22 pm
René
(@rene-3)
RE: XBuddy Board assembly issue
Can you show a picture of that?
Napsal : 11/10/2023 8:06 am
Hello
(@hello)
Posted by: @gary-9
Gary
Do live chat on prusa website few possible reasons once we get pictures we could probably narrow it down
Napsal : 11/10/2023 8:53 am
Gary
 Gary
(@gary-8)
Here are 4 pictures I sent to Prusa.
The circuit board is being held to the xbuddy box by one screw in these shots.
Gary
Napsal : 11/10/2023 9:40 am
René
(@rene-3)
Looking at the pictures, i don't think there is anything wrong.
And you can use five M3x6mm screws to secure the board.
Napsal : 11/10/2023 1:21 pm
Gary
 Gary
(@gary-8)
Nothing except that the holes don't line up. If I force them in, I will most certainly crack the board or damage something else in the process. Can I enlarge the holes a bit safely? I have a set of numbered drills.
Gary
Napsal : 11/10/2023 2:31 pm
Hello
(@hello)
Posted by: @gary-8
Gary
Not really the holes are insulated ground to stop them shorting on screws there's no way yo tell how far the insulation goes
Napsal : 11/10/2023 6:59 pm
Gary
 Gary
(@gary-8)
What if I substitute nylon screws in place of the steel ones?
Gary
Napsal : 11/10/2023 7:22 pm
Hello
(@hello)
Posted by: @gary-8
Gary
I guess might void warranty though isint it better to live chat with prusa
Napsal : 11/10/2023 11:39 pm
SweetRide
(@sweetride)
Is the box itself tweaked? Maybe it came with a little twist in it or you tweaked it when you were attaching it to the frame. I would loosen the box screws a little and give it a little torque action to see if you can get it trued up. Then be extra careful when you re-tighten it up.
Napsal : 12/10/2023 1:11 am
René
(@rene-3)
As I indicated, there is nothing wrong.
Just use the five metal screws provided by Prusa.
You don't have to worry that this will cause damage to the PCB.
It is made of epoxy and can handle a lot of forces.
Do NOT drill out the holes!
Do not use nylon screws!
(The PCB is earthed to the housing through the metal screws)
Napsal : 12/10/2023 6:23 am
iftibashir
(@iftibashir)
Post an image of the entire buddy board case - without the board in it and then with the board lined up.
Napsal : 16/10/2023 7:54 am
Gary
 Gary
(@gary-8)
Those photos are not going to happen.
I was able to get 3 screws in the board. It seemed to be held in place ok so I've continued with the assembly. By now the board is covered with cables and zip ties.
Gary
Napsal : 16/10/2023 5:01 pm
