upgrading the vanilla MK3 with the soldered heated cables
Chris P
(@chris-p-4)
Hi, so I've ordered the MK3S+ to MK4 upgrade kit...My MK3S+ is actually a MK2S that is upgraded through the MK2S to MK3 upgrade kit. It came with a heated with soldered on cables. Since the upgrade kit states that the cables need to be replaced to the heated I am wondering how this will go or that Prusa forgot that there are some heated beds with soldered wiring out there....
Veröffentlicht : 24/04/2023 10:04 am
K7ZPJ
(@k7zpj)
RE: upgrading the vanilla MK3 with the soldered heated cables
I would contact support via the chat window.
I asked about the heat bed and was told that the only parts that will be reused in the MK3+ to MK4 upgrade is the power supply and the Frame.  If you have the silver power supply, I would ask if it is compatible with the upgrade.
Keep a copy of the reply.
Veröffentlicht : 24/04/2023 2:28 pm
James Kirk
(@james-kirk)
https://www.prusa3d.com/product/original-prusa-i3-mk3-s-to-mk4-upgrade-kit/
Parts kept from your MK3S/MK3S+
Frame and extrusions (new MK4 has just a different look)*
PSU** (same wattage/voltage as MK4)
Heatbed MK52 24V (thermistor and power cables will be changed) *
X/Y rods and bearings
Veröffentlicht : 24/04/2023 5:33 pm
