Royal Blue problems on first layer
Hello
galaxy black and silver gray prusament work perfect on my newly assembled MK4, but when I tried to print with this filament :
First layer always gets stringy, and has visible lines. The rest of the print is really nice, which is too bad !
I tried to lower the heat of nozzle to 215 and heat bed to 55 degrees, but no difference.
Any advice please ?
Thank you
Napsal : 27/04/2024 4:43 pm
RE: Royal Blue problems on first layer
wich sheet do you use ? smooth or satin ?
since prusament usually works great. Maybe yours is too moist ?
Napsal : 29/04/2024 11:38 am
Topic starter
answered:
i got a much better result by raising my temps to 240 nozzle and 70 heatbed. New spool from the box, so no humidity, you have to heat it more than stated on the box.
Thank you
Napsal : 29/04/2024 11:47 am
