Purpose / Necessity of Filament Sensor Cover?
Jeff Hawkins
(@jeff-hawkins)
Just received and set up an MK4. A piece of plastic with a brass fitting in it was in the box, but not pre-assembled. Google says this is a filament sensor cover.
I notice that most people don't seem to have it installed when I find videos of people using this printer. What is this part for? And should I install it?
Thanks in advance.
This topic was modified 3 years temu by Jeff Hawkins
Opublikowany : 26/10/2023 11:24 pm
James Kirk
(@james-kirk)
RE: Purpose / Necessity of Filament Sensor Cover?
This is the cover for the MK3 Extruder.
The brass screw thread is to mount an adapter for a ptfe tube. E.g. if you use the enclosure.
Opublikowany : 27/10/2023 1:44 pm
