Prusa MK4 90 Deg Heatbed Cable Bracket for IKEA Enclosure
MaVeRa
(@mavera)
Hello colleagues! I need a this part Prusa MK4 90 Deg Heatbed Cable Bracket for IKEA Enclosure. 60 or 90 is best angle?
Please hit me up with a link to a 3d model.
Thank you!
Postato : 15/12/2023 5:35 pm
Witties3D
(@witties3d)
RE: Prusa MK4 90 Deg Heatbed Cable Bracket for IKEA Enclosure
This one works great
https://www.printables.com/model/220863-prusa-mk3-ring-terminal-90-deg-heatbed-cable-cover
Posted by: @mavera
Thank you!
Postato : 15/12/2023 7:04 pm
1 persone hanno apprezzato
I'm using this 6o degree connector with my Mk4 printers: https://www.printables.com/model/536937
Postato : 15/12/2023 8:11 pm
MaVeRa
(@mavera)
Thanks for your help!
Postato : 15/12/2023 9:31 pm
MaVeRa
(@mavera)
Hello! Is it mandatory to replace the Heatbed Cable Cover 60 Degree when we have an Ikea closure. The cables rest in the polycarbonate at the back of the box, when the bed is in the rearmost position?
    I printed them from Prusament PETG, but I have to disassemble a lot of things to install them, and the power supply is out of the box and the cables are very short. The space I've chosen for the printer with the box is tight and very laborious to work with, at least for now. In principle, the original part is cast from PETG or from ABS, ASA??
Thank you!
Postato : 18/12/2023 11:11 am
Zappes
(@zappes)
It's just a PETG part.
My models on Printables
Postato : 18/12/2023 11:36 am
Artur5
(@artur5)
Yes, the original Prusa cable bracket is PETG but I strongly recommend printing it from a filament more heat resistant ( ABS/ASA/PC) if you print often with the bed at temperatures higher than 80C. Take into account that the bracket is in close contact with the edge of the bed and PETG filament starts to loose rigidity above 70C. I had to replace mine after printing a bunch of ASA parts, because it was sagging visibly.
Postato : 18/12/2023 11:50 am
With the original straight cover, the cable bundle will hit the back of the enclosure when the bed slides to its rearmost position. So unless you move your printer forward so much that the LCD display sticks out, you should replace it with a 60 degrees or more cover.
The original cover is made from PETG. However, I had it melt on two of my Mk3S after a year or so, so I replaced it with one I printed with PC-CF (ASA/ABS would be fine two). If you only intend to print PLA and PETG, a PETG cover would probably be okay but I've printed PC-CF and ASA as well so the heatbed gets heated up more.
Postato : 18/12/2023 11:53 am
MaVeRa
(@mavera)
Thanks everyone for the replies! I think I understood. After I purchase my ASA I will print a new set, but I won't be in a rush.
Postato : 18/12/2023 12:54 pm
