[Resuelto] prints i sliced keep failing
aldenshinn
(@aldenshinn)
whenever I try to print something I sliced it will pause for 2 to 5 min then give me the option to retry print I think I'm messing up the slicing somewhere dose anyone have a solution to this?
Best Answer by FoxRun3D:
Nothing in that file that looks weird and would explain the behavior you're seeing, so I don't think it's slicer related. I would reinstall the latest firmware on the printer and then do a factory reset.
Respondido : 02/01/2024 2:52 am
RE: prints i sliced keep failing
There's really no detail here to work with. Best way to get advice is to set up your project in Prusaslicer, then use File->Save project as to save it as a 3mf file. Next, use your computer's compress utility to convert it into .zip file. Create a post here and use the Attach file button under the text edit box to attach the .zip file (it has to be zip compressed, the forum software will not accept .3mf files).
A 3mf file contains your STL model but most importantly all your settings, so folks here can check to see what's going on.
Respondido : 02/01/2024 1:16 pm
aldenshinn
(@aldenshinn)
ok here it is
PWNoseCone
Esta publicación ha sido modificada el hace 2 years por aldenshinn
Respondido : 02/01/2024 4:58 pm
That printed fine on my Mk3.9
Respondido : 02/01/2024 6:58 pm
Respondido : 02/01/2024 7:02 pm
aldenshinn
(@aldenshinn)
ok i will try that thanks
Respondido : 03/01/2024 12:22 am
aldenshinn
(@aldenshinn)
thank you so much its working i have been trying to get it to work since christmas and updating the firmware fixed it
Respondido : 03/01/2024 5:36 pm
