Printer isn't working correctly after changing nozzle
Heatrice
(@heatrice)
Hello all
After changing out the default nozzle for the v6 adapter nozzle I had a print fail where it failed to print the top 5% or so of it at all for a benchy and another print. So I changed back to the default and now I am having clicking from the extruder and can not start a print.
I have gone through all of the trouble shooting of checking the gear and blowing it out and checking for additional clogs in the nozzle, but that does not seem to be an issue as it purges filament fine.
When I go to unload filament I have to pull to remove it and it does come out crushed/stringy.
When I start a print, even ones it did fine before I changed the nozzle the first time, it will go through all the steps and purge the filament, but when it comes to actually printing, it starts clicking loudly and no filament comes out.
What else could I try? Could the failed print have been the extruder already breaking?
I have only had the printer a few days.
Napsal : 31/03/2024 6:10 am
Heatrice
(@heatrice)
RE: Printer isn't working correctly after changing nozzle
I seem to have done a cold pull before I knew what that was. Extruder pushed out the first purge fine, now to try to print again
Napsal : 31/03/2024 12:49 pm
Heatrice
(@heatrice)
It still will not print correctly while being able to purge.
The print starts and then after a few layers nothing is coming out
Napsal : 31/03/2024 1:13 pm
Me
 Me
(@me-2)
idk, what size of nozzle did you install? did you update it in the printer settings?
Napsal : 09/04/2024 4:44 pm
