Odd layer shift
DavidR
(@davidr-2)
Odd layer shift
Seeing an odd layer-shift issue. I'm printing a lot of this object, and they're meant to fit together tightly, so while I can clean this up with a deburring tool, it's still something I'm seeing too much of after updating to the latest firmware.
The issue first showed up a less complex object, and the layer shift occurs when a new top layer is put down, and then corrects itself after the last top layer. This layer shift is consistent across multiple prints (4 prints total, 1 failed).
I was able to fix the issue on the first object by switching from rectilinear infill to honeycomb. however, the object I've posted a picture of has honeycomb infill.
Best Answer by DavidR:
Switched to the Hilbert Curve for my top fill pattern, that seems to have corrected the issue, or at least countered whatever is going on.
Veröffentlicht : 20/02/2024 10:38 pm
DavidR
(@davidr-2)
RE: Odd layer shift
Veröffentlicht : 22/02/2024 1:26 pm
