[Solved] MK4 vibration/rattling noise - Y-carriage
Bigzh
(@bigzh)
Hello all fellow users, im experiencing alot of rattling/vibration from the Y-carriage. Is there any one that has a quick fix for this?
Video of senario.
IMG_3462
I thought first it was coming from the printers X-carriage. But after some investigation i can confrim its coming from the X-carriage/heatbed.
Not found any solution yet to solve the problem unfortunately.
What i have tried:
- Lubricate the rods
- Torque check of bolts and nuts
- Check with support. But we couldnt find any solution as I had limited time for the fault finding process. Will try some more when I have the time.
- Running printer on squash ball stands.
Best Answer by Bigzh:
Hi again, problem is fixed. 100% motor problem that caused the rattling.
Took 10 min to change the motor, so its a easy step if you have a pre-assemble printer as mine.
***Only miss steps by Prusa is they forgot to send a new termal tape with the motor. Luckly I had some spare tape/plate from a other project I needed termal tapes.
Posted : 17/07/2023 11:53 am
jvasileff
(@jvasileff)
RE: MK4 vibration/rattling noise - Y-carriage
It's worth checking to make sure no hardware or debris found its way into one of the aluminum extrusions.
Posted : 17/07/2023 9:45 pm
Bigzh
(@bigzh)
Hi again, after checking with support again. They can confirm there has been a issue/problem with the Y-axis motors shipped in some batches. I was therefore sent a new motor as mine has a minor defect. Printer works, but irritating sound as seen in the video attached.
Posted : 18/07/2023 6:54 pm
JoshuaGranger13
(@joshuagranger13)
@bigzh: can you confirm the new motor fixed the problem? mine sounds exactly like yours when printing
Posted : 25/07/2023 7:18 pm
Bigzh
(@bigzh)
Posted : 27/07/2023 12:10 am
Kuraperan3D
(@kuraperan3d)
Hi, I'm still waiting for my own kit, but is there any way to detect the versions of the engines.
Posted by: @bigzh
Disclaimer: My English relies heavily on Google Translate 🙂
Posted : 12/08/2023 7:34 am
Kuraperan3D
(@kuraperan3d)
the engines
motors i mean
Posted : 21/08/2023 12:15 am
Bigzh
(@bigzh)
They way to detect it is to send the QR code and serial code to support. When the problem appears. They can confirm if its related to a bad batch.
Posted : 22/08/2023 1:35 pm
