Discrepancy Between Reported Print Completion and Actual Progress on Prusa MK4
Preppo
(@preppo)
Utenti
During a 3D print job, I made several adjustments to the print speed using the "Tune" function on the printer's display. I decreased the print speed from 100% to 95%, then to 90%, and finally to 80%. After making these changes, I did not closely monitor the printer and left it to complete the print.
To my surprise, the printer eventually reported that the print was 100% complete and moved the print head to the park position. However, upon inspection, I discovered that the printed object was only around 60% finished.
I'm unsure about what could have caused this discrepancy between the reported completion and the actual progress of the print. I suspect it may be related to the adjustments I made to the print speed during the process.
Could you please help me understand what might have gone wrong in this situation?
Best Answer by jkavalik:
So you came to a finished incomplete print? That sounds more like a nozzle clogged or filament snapped or got caught somewhere so it was not actually printing for some time, doing all the moves but depositing no plastic.
Postato : 01/06/2023 6:59 am
jkavalik
(@jkavalik)
Utenti
RE: Discrepancy Between Reported Print Completion and Actual Progress on Prusa MK4
Postato : 01/06/2023 8:01 am
Preppo
(@preppo)
Utenti
It was clogged. First clogged nozzle for me. I focused only on my changed printing speed parameter.
How do I prevent the nozzle from clogging the next time?
I reduced the print speed to 80%, so I quess the 215°C hotend heat could creep up more the nozzle tube and melt the filament at/before the "heat break" (copper ring)?
So should I therefore reduce the hotend temperature as well to compensate for the reduced extrusion?
Postato : 01/06/2023 12:53 pm
