Build MK4 With MMU3 PCCF Nextruder Parts And Add MMU3 Later?
DonD
 DonD
(@dond)
I have an MK4 upgrade kit and an MMU3 upgrade kit. I plan to build the MK4 now and use it for a while to be sure it is dialed in and then add the MMU3 later. I would like to build the MK4 Nextruder with the special MMU3 PCCF parts now and add the MMU3 later but the chat agent said it was not possible becase the 'filament sensor mechanism works different.'
Since then I read comments in the MMU3 Nextruder mod instructions that mentioned using an MMU3 upgraded MK4 without the MMU by just recalibrating the filament sensor. Can I use this same filament sensor calibration method to use the MMU3 Nextruder parts now without the MMU so I don't have to rebuild the Nextruder later?
Posted : 01/06/2024 5:24 pm
Bjoern
(@bjoern)
RE: Build MK4 With MMU3 PCCF Nextruder Parts And Add MMU3 Later?
Yes I did that, even on my MK4S, upgrade the parts with PCCF and you just have to rerun the filament sensor calibration.
If the MMU3 is unchecked it will just work as a normal MK4/S anyway
Posted : 23/09/2024 5:47 pm
