Filament load presets
codymammenga
(@codymammenga)
I am wondering if there is a way to add more filament presets in the menu on the machine?  I use PCTG and I also use another higher temp PETG and I have to manually go in and heat up the hot end then select PETG and then when I slice it and go to print they always tell me there is a different filament loaded would you like to still continue?  I looked in the menus and tried searching here but couldn't find anything to help me create a couple filament presets or adjust the factory presets?
Napsal : 10/02/2025 6:49 pm
3Delight
(@3delight)
Moderátor Moderator
RE: Filament load presets
If you go to the Filaments tab  at the top and click the little Floppy Disk symbol next to Preset name drop down, it will let you save new Filament Presets under a new name.
Napsal : 10/02/2025 6:55 pm
codymammenga
(@codymammenga)
Are you talking in prusa slicer? I am talking about on the machine itself.  I didn’t see a floppy disc on the filament menu on the machine itself.  I am wanting to change those as there is no PCTG and my PETG needs to be 250 to load on the hot end and at the factory 230 I get extruder clicking
Napsal : 11/02/2025 2:24 pm
Fortust
(@fortust)
Posted by: @codymammenga
Unfortunately, most machines don’t allow custom filament presets directly on the printer. You can try editing the material profiles in your slicer and name them accordingly—then match those settings manually on the printer.
crazy flips 3d
Napsal : 24/06/2025 3:18 am
