6.5.3-RC Firmware for Prusa MK3.9S
Jan Kratochvíl
(@jan-kratochvil)
Miembro Admin
Summary
    • New features and improvements
  • Massively speed up MMU filament changes [MMU]
  • Updated default input shaper profiles [C1, C1L]
  • Updated translations (beta didn’t have new texts translated)
  • (+ changes from the beta)
  • Fixes
  • M1704 MMU load test gcode now considers toolmapping [MMU]
  • Fixed MMU sending spurious attention reports to Prusa Connect during normal toolchanges [MMU]
A series of improvements have been implemented that massively speed up MMU filament changes by up to 9 seconds. Some changes in the MMU firmware were required as well, so it is necessary to flash a new 3.0.4 firmware to your MMU unit.
The improvements include:
  • Parallelized unloading filament from the nozzle and idler engaging.
  • The printer does not wait for the final idler disengagement to finish to continue printing.
  • Parallelized selector and idler movement.
  • FeedingToFinda phase now obeys PulleySlowFeedrate with higher value.
  • Optimized idler selection mechanism during filament change.
In 6.5.3-beta, we’ve fixed a bug causing input shaper configurations to be swapped on the CoreXY printers. As a result, new input shaper profiles needed to be calibrated as well.
If you have Core ONE L or an accelerometer accessory, we recommend re-running your input shaper calibration.
If you don’t have an accelerometer, we recommend resetting your input shaper profiles to defaults using the Settings → Input Shaper → Restore Defaults. If you haven’t changed your input shaper settings, the values should update automatically.
Release notes
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.5.3-RC
Respondido : 16/03/2026 2:08 pm
