[Solved] expansion joins on y axis base plate
spofali
(@spofali)
Hello, I'm tring to install the expansion joins on the y axis plate but the holes on the top of expansion joint parts is too small for the 2.0mm allen key to go through the top hole on the expansion join for the screws to be tighting. Am I doing it wrong or is there any other way of assembly?
Napsal : 10/06/2025 11:00 am
