Could I get some help please? Mk3.5s prints not finishing. New to the Revo 6
Grarea
(@grarea)
I posted this on reddit, then I remembered this forum. Which even has a section for my model 🙂
https://imgur.com/a/ZEgjNPA
https://imgur.com/a/0PFStx8
https://imgur.com/a/147CmvJ
https://imgur.com/a/S07eDUO
Some info. I have used a MK3S for a few years, but only bits and bobs. I have pretty much always used presets. With octoprint on pi4. So, still very much a noob.
I picked up a second hand MK3.5S with E3d revo. I use a pi5 as my desktop, so have reinstalled prusaslicer, but held it back to v2.7.1 (I will need to check that when I get home if relevant.) But it only has the Mk3.5, not the MK3.5S. So the first pic is the test but micro. I then switched to the mini test as I knew that to be working model. Resliced with stock presets. Then I swapped from the prusament filament that worked on the mk3s because my boiler broke and I had a cold couple of weeks, so wondered if filament got damp? New, but previously untried Uzy filament.
On the last run, it stopped feeding filament. When I went to purge, it did nothing. I had to push the filament quite hard to get it to grab.
Also, if you look at pic, it looks a bit squiggly. I can't find anything about needing to change settings for revo. Could it mean it might not be installed quite right? Or do I need to adjust presets?
Thanks.
Napsal : 24/01/2025 4:29 am
