3.5 Upgrade with Silver PSU and enclosure
I just finished upgrading My MK3S+ to 3.5 with a silver PSU, and all is well.
Except, this printer was in an enclosure and I built it up stock outside the enclosure.
The upgrade with the silver PSU has an extension cable, which I believe is a ground, that connects to the printer frame then up to the back of the PSU.
So what modifications are needed to move the PSU back off the frame so I can mount it outside the enclosure?
Does the ground need to stay on the frame or is that just a mounting point?
Can I swing it to the other side, mount it there, and make a longer cable to route outside the enclosure to the PSU?
Thanks.
Respondido : 23/12/2025 3:33 am
