Help with First Layer Configuration
Pagina 2 / 2
Tom in VA
(@tom-in-va)
RE: Help with First Layer Configuration
Well, that's one way to fix that problem. Good Luck
Postato : 17/04/2025 11:25 pm
Andrew M
(@andrew-m-2)
Utenti
Hello, I am having a similar issue.
For context I own 4 mk3s printers and one I have recently converted to Mk3,5s with 0.6mm nozzle after putting roughly 1500hours on it. I am finding using the first layer calibration tool gives good results but when you go to print a part at say 0.32mm layer height 0.2mm first layer, the first layer is way off and I have to adjust z offset to get a good first layer again. I also have to slow it down to roughly 50% speed. once I have a good first layer I can crank the speed back up to 100% and get a good part.
It appears like the first layer tool doesn't apply z offset appropriately depending on what layer height you print at. same issue for PLA OR PETG smooth or textured bed. No improvement with dried filament and printer in tent. Tried clean beds (soapy water) or with glue stick no difference.
Slicer 2.9.4
Firmware 6.5.3
Postato : 12/05/2026 6:00 am
Pagina 2 / 2
