Something broke (resets after initiating print)
ryan kubik
(@ryan-kubik)
I've been battling print adhesion problems, I've tried washing the bed with soap and then alcohol, adding brims, messing with the Z axis offset, everything, with no avail.
Anyway, this time the brim let go suddenly, and it seems to of jammed up the nozzle. So, I clean the nozzle peel the filament off and get everything cleaned up. Go to try and print again and as soon as I hit print and then bed turns on, it trips and resets and also loses the fact there's an SD card in there. I need to unplug it and replug it in and then it sees the SD card.
Not sure where to start with trouble shooting? I'm thinking I blew a fuse somewhere maybe?
Have had this printer for 4 years or so running like a top, I feel like now in 2 or 3 days everything is wrong with it all at once 🤣
Any help is appreciated!
Napsal : 19/01/2025 9:22 pm
