Printer repeats layer in loop then jumps to a different height (+ 6mm) after pausing and unpausing print.
I am trying to print a file but every time I run the print from the SD card it starts the after a few layers gets caught in a loop for an indeterminate period of time then jumps to a much higher layer and starts printing again. I have tried Prusaslicer, Flashprint 5, and Cura and all have them same error. I am confident it is not the G-code as I stated I have used multiple slicers. I have run a self test and everything checks out. I have run through a full factory reset and recalibrated everything and it passes. Does anyone have any insight as to what to do moving forward? Thanks.
Veröffentlicht : 21/01/2026 5:55 pm
