Printer repeats layer in loop then jumps to a different height (+ 6mm) after pausing and unpausing print.
BryceP
(@brycep)
I am trying to print a file but every time I run the print from the SD card it starts the after a few layers gets caught in a loop for an indeterminate period of time then jumps to a much higher layer and starts printing again.  I have tried Prusaslicer, Flashprint 5, and Cura and all have them same error.  I am confident it is not the G-code as I stated I have used multiple slicers.  I have run a self test and everything checks out.  I have run through a full factory reset and recalibrated everything and it passes.  Does anyone have any insight as to what to do moving forward?  Thanks.
Opublikowany : 21/01/2026 5:55 pm
Robin_13
(@robin_13)
RE: Printer repeats layer in loop then jumps to a different height (+ 6mm) after pausing and unpausing print.
I know I am late but you can look at the gcode and read the Z values to confirm.  If I have an issue, this is the best option to confirm the gcode.
Opublikowany : 01/03/2026 5:13 am
