Pid tunning and fan errors.
CiberTea Lda
(@cibertea-lda)
Well upgraded my trusty MK3S+ to a Mk3.5S+, so far so good.
On the i initial self test noticed the fan test to be annoyed because my part cooling fan was a another model and has more RPM, and better flow... , now a added a better part cooling unit that blows the air all arroun and it complains again that has a thermal runaway... this was easy to solve on the mk3s+... just did the thermal model calibration and no issues... but now i dont have the option... after searching did not found any reference to it apart to do it the old way on pronterface by command line ( no isues here, as long as it works.... but again the printer stall to stabilize the heat woth the fan on, and gives thermal runaway ... got it to complete with the fan off , but it did no save to eprom with the m500 command...
So what i need it at least to be able to add the feature to the firmware, anyone knows it this is possible to activate on the Souce code to appear on screen? Or activate MCP on the printer...
Thanks in advance!
Posted : 30/05/2025 6:37 pm
