Network issues 3.5 upgrade
Paul H
(@paul-h-2)
Mitglied
Upgraded my second 3S to 3.5.  First one went great and it's been solid. I really like using PrusaLink.
This second upgrade however.....  Connected to wired ethernet, using the same cable and switch port as I was using prior to the upgrade, and it never gets an IP address.  Also not able to set a static address.  Wifi does connect to the network, but I'm not able to connect to PrusaLink.
I've tried different network cables, and a different network switch.  Those cables work on my other two printers.
Really baffled that I can't get this thing on the network.  I'd much prefer a wired connection.  Any help is appreciated!
Veröffentlicht : 23/06/2025 12:40 am
BMC
 BMC
(@bmc)
RE: Network issues 3.5 upgrade
I just completed my first upgrade of two machines and it doesn’t detect the WiFi.  It says it’s “gone.”  I unplugged it and plugged it back in with no effect.  It has the newest firmware.
Any solution to this?
Veröffentlicht : 16/08/2025 3:11 pm
