MK3.5 purge line at the back of the printer
I'm facing a strange issue with my printer. After performing a factory reset and running the calibration wizard, the printer behaves as if it's mirrored along the Y-axis. For instance, it starts printing the purge line at the back of the printer instead of the front.
Did I accidentally select an incorrect setting during the setup process? Or is there something else I might have done wrong?
Opublikowany : 18/12/2024 10:59 pm
