Losing temp at nozzle, machine states nozzle is at temp.
I have an odd issue with one of my printers.
The machine says it is holding temp steady at 215c while printing. However, it loses temperature at the nozzle and stops extruding. I ruled out a clog, actually replaced the whole hot end assembly with a brand new one. It seemed to solve the problem at first. I got about 2 large prints done and during mid print on the third I lost temperature. It's not a problem with the print file as I have printed these same files on other machines. This morning I have taken that hot end off and put it on another machine and it is working just fine. I did check the board for loose connections, not problems there that I could see. Thoughts on what I should try next?
Postato : 08/12/2025 5:44 pm
