RE: Display problem
When my LCD had a problem like yours I ended up replacing the LCD.
But, first check the LCD cables for any damage and then reseat the connectors on both ends.
Opublikowany : 25/11/2024 1:05 am
RE: Display problem
You can adjust the brightness of the display at the back, or in the menu depending on your display version.
Opublikowany : 15/12/2024 12:57 pm
