Default printer hardware settings after upgrde form MK3S+ to MK3.5S
[Solved] Default printer hardware settings after upgrde form MK3S+ to MK3.5S
Sandmännchen
(@sandmannchen)
Hello,
I have just finished upgrading from MK3S+ to MK3.5S. Everything works fine! 🙂
After upgrading the firmware I am a little bit confused about the default firmware settings.
The default printhead settings are 0.4 HF nozzle type and hotend with sock.
I have the standard MK3S+ from 2021 and I have never changed the hotend nor nozzle. So I have to change the settings to 0.4 standard nozzle and hotend to Stock.
Right?
Christian
Posted : 24/01/2026 10:28 pm
RE: Default printer hardware settings after upgrde form MK3S+ to MK3.5S
You got it!
Posted : 25/01/2026 12:56 pm
