Banging plate X and Y stops
SteveS
(@steves)
Since putting the latest firmware on the machine i notice that it beats seven shades on the X and Y axis, banging the end stop, before it starts to print.
Why?
Never did this before!
Opublikowany : 05/12/2024 7:25 pm
Blacksceada
(@blacksceada)
RE: Banging plate X and Y stops
As I purchased a MK3S+ and converted it directly to MK3.5S, without a single print done, I would like to know if this is the normal behavior of the MK3.5S?
Mine does that too. But I thought that's normal...
Did you solve the problem in the meantime? Or maybe someone can report if it is intended behavior?
Opublikowany : 09/02/2025 8:18 pm
BIGRED
(@bigred)
I noticed it too, did it the first time after the new firmware was installed, then stopped 🤷‍♂️
Opublikowany : 19/02/2025 3:07 am
