Easy and Quick Steel Sheet Offset Adjustment - Any way other than running the calibration?
For calibrating the offset for my print sheets, I print a set of 25cm squares in a 5x5 grid so I can get a clear idea of just what it looks like for a 1st layer. It takes more time than the Prusa built-in calibration test, but it's more thorough. Once I get the offset worked out through this, I've found I can't just "dial it in" for a sheet. I have to go to Settings->Hardware->Steel Sheets and pick the sheet I'm using and run the 1st layer calibration. I tried to just pick the offset and change it, but that won't work. I have to set it by printing the calibration test.
Is there a way to change the offset for a steel sheet other than running through the calibration test?
Opublikowany : 08/09/2024 9:09 pm
