Stuck in Calibration 'loop'
ssable
(@ssable)
Hi
I have a MK3S+ which used to work fine, but has now developed a fault whereby it is is constantly displaying that the Printer has not been calibrated yet.
I have tried re-calibrating, and it appear sot go thru the process ok. All settings and setup are just fine.
As soon as I try to load filament or run a job I get the "Printer has not been calibrated yet, please follow the manual, chapter First steps, calibration flow" message.
I have done this many times and it appear sot be stuck in this calibration / message loop.
I have done factory re-sets, re-loaded firmware (various versions) and re-calibrated each time, but with no success. Printer just want to calibrate all the time.[caption =
Any pointers are much appreciated.
Thanks all.
Napsal : 09/05/2025 1:31 pm
briand42956
(@briand42956)
RE: Stuck in Calibration 'loop'
What firmware are you on? I am getting this now too and I have completed all the calibrations, or so I think. I just upgraded from MK3 to MK3S and added the MMU2S upgrade on. Had these for years and finally just did them. I'm on MK3S v3.14.1-8237
MK3S with MMU2S
Napsal : 15/01/2026 2:14 am
