Layer shifting help
I have tried this print twice with the same result. the long walls of the box show layer shifting for half the height of the print then revert to normal. The shorter walls are fine. I have never had this happen before.
Would anyone have an explanation and possible solution.
I am using a Prusa Mk.3.5s with updated firmware.
Veröffentlicht : 22/05/2026 1:09 am
Check your axis drive gear is not slipping on the shaft - make sure the grub screw is correctly positioned.
Veröffentlicht : 22/05/2026 9:55 am
