XYZ Calibration failed. Bed calibration point was not found
Hi Guys
This fails on the 1st of 4. I have carried out all the remedies I can see on posts etc. been at it for a few days now with no luck.
Anyone with definitive answers or anyone in Brisbane that can help.
Cheers
RE: XYZ Calibration failed. Bed calibration point was not found
Hi Michael,
I am the new here too and had the same problem.... 🙁
BUT it is solved….(right now) the trouble was in wrongly installed hotend. Hotend was installed too low in extruder.
Verify your PINDA height following the installation instructions, I would suspect that it may be too high to get the 1st calibration point.
Good luck, be safe.
Phil
Stay safe and healthy, Phil
I found the problem. It worked when I did it without the paper.
Don't forget to keep the bearing rods oiled. To much drag on the bearings causes big problems with calibration.
